philco model 60
Hi d and wellcome to the phoum
Let me ask you has the set been serviced within the last few years? Could be a number of things, but you've come to the right place to find out what the problem is.
philco model 60 - by d smith - 03-21-2012, 06:59 PM
RE: philco model 60 - by Ron Ramirez - 03-21-2012, 07:33 PM
RE: philco model 60 - by d smith - 03-21-2012, 07:52 PM
RE: philco model 60 - by 7estatdef - 03-21-2012, 08:06 PM
RE: philco model 60 - by d smith - 03-21-2012, 09:39 PM
RE: philco model 60 - by TA Forbes - 03-21-2012, 11:22 PM
RE: philco model 60 - by d smith - 03-24-2012, 03:01 PM
RE: philco model 60 - by tab10672 - 03-24-2012, 05:18 PM
RE: philco model 60 - by d smith - 03-24-2012, 09:45 PM
Philco 91 Tuning Condenser
There are currently 5200 online users. [Complete List]
» 1 Member(s) | 5199 Guest(s)
