Philco 80 Jr, just starting....
That is kind of interesting, the 2 #36 tubes in my 80 when I got it tested weak, but identical on my Hickok, but only one would work in the 1st stage.
It took me 3 tries over 3 days to get the alignment right where the dial tracked and there wasn't a change in volume at the low or high end when I touched the 1st 36's grid.
But I'll tell you what, the little guy works pretty good, abet the volume control is a little 'jumpy'. Not bad for a radio Philco didn't want to sell.
John
Las Vegas, NV USA
Philco 80 Jr, just starting.... - by morzh - 01-28-2012, 09:35 PM
RE: Philco 80 Jr, just starting.... - by morzh - 02-29-2012, 12:21 AM
RE: Philco 80 Jr, just starting.... - by morzh - 03-15-2012, 12:05 AM
RE: Philco 80 Jr, just starting.... - by codefox1 - 03-15-2012, 01:25 AM
RE: Philco 80 Jr, just starting.... - by morzh - 03-15-2012, 10:44 AM
RE: Philco 80 Jr, just starting.... - by codefox1 - 03-15-2012, 12:20 PM
RE: Philco 80 Jr, just starting.... - by morzh - 03-17-2012, 01:14 AM
RE: Philco 80 Jr, just starting.... - by morzh - 03-21-2012, 03:35 PM
RE: Philco 80 Jr, just starting.... - by morzh - 03-21-2012, 11:03 PM
RE: Philco 80 Jr, just starting.... - by LASJayhawk - 03-21-2012, 08:46 PM
RE: Philco 80 Jr, just starting.... - by morzh - 03-21-2012, 10:56 PM
Re: Philco 80 Jr, just starting.... - by morzh - 01-29-2012, 03:24 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-05-2012, 06:23 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-06-2012, 06:31 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-11-2012, 08:25 PM
Re: Philco 80 Jr, just starting.... - by codefox1 - 02-11-2012, 09:50 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-12-2012, 11:14 PM
Re: Philco 80 Jr, just starting.... - by codefox1 - 02-13-2012, 04:22 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-13-2012, 06:37 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-15-2012, 12:50 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7297 online users. [Complete List]
» 3 Member(s) | 7294 Guest(s)
