  • 1 Vote(s) - 4 Average
Philco 37-116X What's The Price Point?
I see a couple of the members have recently picked up model 116's. There is a 37-116X available for $195. Is this reasonable? My 2005 Slusser's lists it at $200-230. Looks to be in decent shape, no visible tears on the grill cloth, but the chassis has been attached using a metal strap at each end. It's a 2+ hr drive each way so $50 in fuel. Any thoughts would be appreciated. Thanks,
Gene
Philco 37-116X What's The Price Point? - by Gene Pederson - 03-22-2012, 06:20 PM
Philco 91 Tuning Condenser
