41-95 cap
You're correct Chris - there is no part at 0.25 uF. in the 41-95. Since the surviving end is connected to ground, the only two caps it could be are #11 and #12. Both are 0.05 uF @200V. as the Parts List shows.
The only other caps to ground are #10, the electrolytic on the B+ line and $8 a mica cap. The unlabeld cap on the 2nd. IFT shown in the schematic is internal to the IF can and is probably a mica as well.
Just use the schematic to check the connections to these two caps to discover which it is.
41-95 cap - by Chris Drumma - 11-29-2006, 08:46 AM
[No subject] - by Chuck Schwark - 11-29-2006, 10:12 AM
