Philco 37-650
I just bought a Philco 37-650.
The cabinet says: Sherman Clay & Co.
Are all Philco cabinets made by this Co?
I can't find much info on this radio.
Thanks, Ray
Philco 37-650 - by Ray P - 03-23-2012, 01:02 PM
RE: Philco 37-650 - by Ron Ramirez - 03-23-2012, 01:32 PM
RE: Philco 37-650 - by Ray P - 03-23-2012, 08:49 PM
RE: Philco 37-650 - by Ron Ramirez - 03-23-2012, 09:00 PM
RE: Philco 37-650 - by Ray P - 03-23-2012, 10:08 PM
RE: Philco 37-650 - by Ray P - 03-24-2012, 10:21 AM
RE: Philco 37-650 - by Ron Ramirez - 03-24-2012, 08:10 PM
RE: Philco 37-650 - by Ray P - 03-25-2012, 03:35 PM
RE: Philco 37-650 - by Ron Ramirez - 03-25-2012, 03:37 PM
There are currently 10419 online users. [Complete List]
» 2 Member(s) | 10417 Guest(s)
