  • 1 Vote(s) - 4 Average
Philco 37-116X What's The Price Point?
(03-23-2012, 03:30 PM)Gene Pederson Wrote:  When I mentioned the probability of the rubber covered wiring the guy says he has worked on electronics since the 70's. All the knobs are missing. Small veneer chip on the top. I don't know who told him it's worth a lot more, but I agree that consoles are harder to sell. I had trouble GIVING one away! The chassis sounds somewhat intimidating to me also.
Maybe I should go look at an RCA K130 instead. That's $150 and a lot closer.
Gene
Hi Gene,
Just did a K130.
Lots of bad rubber coated wires to replace in those.
Nice looking and sounding radio when it was done though.
I like the adjustable antenna in these.
murf
RE: Philco 37-116X What's The Price Point? - by murf - 03-23-2012, 05:51 PM
Philco 91 Tuning Condenser
There are currently 4216 online users. [Complete List]
» 1 Member(s) | 4215 Guest(s)
