Philco 37-84
(03-23-2012, 11:04 PM)Art Hoch Wrote:  Hi guys,
Been working on this nice little cathedral. I've changed the filter caps (but not the caps in the blocks), a couple of resistors, and have it powering up. All I'm getting is a soft hum now. I have a suspicion the oscillator coil isn't working. However, I'm wondering about the caps in the blocks. What do you guys think....caps or coil...or something els?. What's a good test on the osc. coil? Tubes test strong.
Got to do it all and the resistors.
Philco 37-84 - by Art Hoch - 03-23-2012, 11:04 PM
RE: Philco 37-84 - by 7estatdef - 03-23-2012, 11:26 PM
RE: Philco 37-84 - by AI2V - 03-27-2012, 03:10 PM
RE: Philco 37-84 - by Art Hoch - 03-27-2012, 08:06 PM
RE: Philco 37-84 - by codefox1 - 03-27-2012, 08:54 PM
RE: Philco 37-84 - by tab10672 - 03-27-2012, 11:31 PM
RE: Philco 37-84 - by Art Hoch - 03-28-2012, 08:39 PM
RE: Philco 37-84 - by Art Hoch - 03-29-2012, 06:41 PM
RE: Philco 37-84 - by 7estatdef - 03-29-2012, 07:10 PM
RE: Philco 37-84 - by Art Hoch - 04-13-2012, 12:42 PM
RE: Philco 37-84 - by Art Hoch - 04-23-2012, 11:11 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7322 online users. [Complete List]
» 3 Member(s) | 7319 Guest(s)
