Philco 60 tuning cap and chassis grommets-source?
(03-24-2012, 05:29 PM)Allen in SB Wrote:  Hello Lyle:
I recall that my Model 60 (late version) uses four grommets for the tuner. RenovatedRadio sells them in sets of three. You may wish to check your radio to ensure that you receive enough grommets for the complete job.
Good luck!
Thanks for thinking of me, Allen.
I double checked and my 60 has only three grommets. Glad you mentioned it. Better safe than sorry.
Thanks again,
lyle
I may not be very good, but I'm slow.
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5694 online users. [Complete List]
» 1 Member(s) | 5693 Guest(s)
