  • 1 Vote(s) - 4 Average
Philco 37-116X What's The Price Point?
(03-24-2012, 05:58 PM)LASJayhawk Wrote:  Some guy on the barking dog forum Icon_smile Had a picture of a 37 or 38 he did. He unbolted the tuning dial and took all the screws out of all 4 of the sub chassis. thing folded up like a rubics cube. Got to everything without unsoldering anything from the 4 sub chassis.
You can do that on some of the lesser models. But, I can see no way on the 37-116. Wires come in from 3 dirrections and even thought they are not rubber coated, they can be a little brittle, so best not to twist them any more than needed. Really it only took a few minuts to take it out and not much more to put it back. You just have to make sure that everything is back where it started.
RE: Philco 37-116X What's The Price Point? - by Phlogiston - 03-24-2012, 08:34 PM
Philco 91 Tuning Condenser
