  • 1 Vote(s) - 4 Average
Philco 37-116X What's The Price Point?
Gene! Where are you located? Have you seen this thread?
http://philcoradio.com/phorum/showthread.php?tid=4480
FREE 37-116X De Luxe...you pick up.
(03-24-2012, 05:58 PM)LASJayhawk Wrote:  Some guy on the barking dog forum Icon_smile ...
Careful, LASJayhawk...I got yelled at the last time I referred to it as the Alternative Radio Forum...
RE: Philco 37-116X What's The Price Point? - by Ron Ramirez - 03-24-2012, 08:50 PM
Philco 91 Tuning Condenser
