Majestic 181
Jayce
Congratulations on your acquisition! I saw one of those at a local auction many, many years ago, when I was still living in Kentucky. Haven't seen one since. Your set has a dial like a Majestic 71. Very neat radio.
Too bad about the pot metal, but Majestic used the stuff in most if not all of their early sets.
Majestic 181 - by Jayce - 03-23-2012, 11:42 PM
RE: Majestic 181 - by Arran - 03-24-2012, 02:34 AM
RE: Majestic 181 - by Jayce - 03-24-2012, 01:03 PM
RE: Majestic 181 - by Arran - 03-24-2012, 09:26 PM
RE: Majestic 181 - by Ron Ramirez - 03-24-2012, 09:44 PM
RE: Majestic 181 - by Jayce - 03-24-2012, 10:43 PM
RE: Majestic 181 - by Jayce - 03-24-2012, 10:40 PM
RE: Majestic 181 - by Doug Houston - 03-25-2012, 12:56 AM
RE: Majestic 181 - by TA Forbes - 03-25-2012, 12:57 AM
RE: Majestic 181 - by Jayce - 03-25-2012, 01:18 AM
RE: Majestic 181 - by Doug Houston - 03-25-2012, 09:33 PM
RE: Majestic 181 - by Jayce - 03-25-2012, 10:51 PM
RE: Majestic 181 - by Arran - 03-26-2012, 12:05 AM
RE: Majestic 181 - by Doug Houston - 03-26-2012, 11:14 PM
RE: Majestic 181 - by TA Forbes - 03-27-2012, 01:54 PM
RE: Majestic 181 - by codefox1 - 03-27-2012, 09:03 PM
RE: Majestic 181 - by Doug Houston - 04-05-2012, 11:19 PM
RE: Majestic 181 - by Arran - 03-27-2012, 07:43 PM
RE: Majestic 181 - by Jayce - 03-29-2012, 07:56 PM
RE: Majestic 181 - by Arran - 04-03-2012, 11:30 PM
RE: Majestic 181 - by Doug Houston - 03-29-2012, 11:53 PM
RE: Majestic 181 - by Jayce - 04-04-2012, 12:39 AM
RE: Majestic 181 - by codefox1 - 04-04-2012, 02:57 AM
RE: Majestic 181 - by Arran - 04-05-2012, 01:26 AM
There are currently 10501 online users. [Complete List]
» 4 Member(s) | 10497 Guest(s)
AvatarAvatarAvatarAvatar
