Philco 38-60
I dont have this model but it doesnt look like much was changed from the 37-60 same tube lineup so more than likely same chassis? Try that one to see if it will help.
Philco 38-60 - by fixinmyphilco - 03-25-2012, 02:46 PM
RE: Philco 38-60 - by tab10672 - 03-25-2012, 03:27 PM
RE: Philco 38-60 - by TA Forbes - 03-25-2012, 11:47 PM
RE: Philco 38-60 - by fixinmyphilco - 03-26-2012, 06:37 PM
RE: Philco 38-60 - by fixinmyphilco - 04-06-2012, 07:22 PM
RE: Philco 38-60 - by Dave - 04-06-2012, 10:00 PM
RE: Philco 38-60 - by fixinmyphilco - 04-07-2012, 02:54 AM
RE: Philco 38-60 - by Dave - 04-07-2012, 10:41 AM
RE: Philco 38-60 - by TA Forbes - 04-07-2012, 10:53 AM
RE: Philco 38-60 - by fixinmyphilco - 04-12-2012, 05:29 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7825 online users. [Complete List]
» 3 Member(s) | 7822 Guest(s)
