Philco 37-650
(03-24-2012, 08:10 PM)Ron Ramirez Wrote:  Thanks, but I don't expect it to be finished anytime soon. I'm deep into what may be the most challenging radio project I've ever taken on...a 41-616. Icon_eek
http://www.philcoradio.com/phorum/showth...p?tid=4441
Hi Ron
Very nice. Good luck with it.
Philco 37-650 - by Ray P - 03-23-2012, 01:02 PM
RE: Philco 37-650 - by Ron Ramirez - 03-23-2012, 01:32 PM
RE: Philco 37-650 - by Ray P - 03-23-2012, 08:49 PM
RE: Philco 37-650 - by Ron Ramirez - 03-23-2012, 09:00 PM
RE: Philco 37-650 - by Ray P - 03-23-2012, 10:08 PM
RE: Philco 37-650 - by Ray P - 03-24-2012, 10:21 AM
RE: Philco 37-650 - by Ron Ramirez - 03-24-2012, 08:10 PM
RE: Philco 37-650 - by Ray P - 03-25-2012, 03:35 PM
RE: Philco 37-650 - by Ron Ramirez - 03-25-2012, 03:37 PM
There are currently 7219 online users. [Complete List]
» 1 Member(s) | 7218 Guest(s)
