Another 47-1230 restoration?!
I finished replacing the electrolytic and paper caps in the set and replaced a couple bad tubes. It is playing on AM and I got the phonograph working but no luck with FM yet. I will revisit that a little later.
I am also looking for the correct dial scale. At some point in the past it was removed, and a blank glass pane with an inkjet printout (incorrect too) dial scale was substituted. I have been unable to locate a replacement through any of the parts suppliers listed on this and other websites. Does anyone have an extra or know of where I could purchase one?
Another 47-1230 restoration?! - by LedHed - 01-27-2012, 08:43 PM
RE: Another 47-1230 restoration?! - by LedHed - 03-25-2012, 08:20 PM
RE: Another 47-1230 restoration?! - by TA Forbes - 03-25-2012, 11:50 PM
RE: Another 47-1230 restoration?! - by LedHed - 03-26-2012, 12:06 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6918 online users. [Complete List]
» 1 Member(s) | 6917 Guest(s)
