Majestic 181
Bleah, I've dealt with Japanese broker agents on eBay before, on vintage inflatable toys and inflatable promotions of all things. Had tried to get a big Uniroyal tiger years back and a couple Japanese dealers were sucking the stuff up as fast as it could be listed, for rediculous prices. I like the Japanese, but stuff like that sometimes makes me want to slap one of them. Caused a lot of flustration.
Majestic 181 - by Jayce - 03-23-2012, 11:42 PM
RE: Majestic 181 - by Arran - 03-24-2012, 02:34 AM
RE: Majestic 181 - by Jayce - 03-24-2012, 01:03 PM
RE: Majestic 181 - by Arran - 03-24-2012, 09:26 PM
RE: Majestic 181 - by Ron Ramirez - 03-24-2012, 09:44 PM
RE: Majestic 181 - by Jayce - 03-24-2012, 10:43 PM
RE: Majestic 181 - by Jayce - 03-24-2012, 10:40 PM
RE: Majestic 181 - by Doug Houston - 03-25-2012, 12:56 AM
RE: Majestic 181 - by TA Forbes - 03-25-2012, 12:57 AM
RE: Majestic 181 - by Jayce - 03-25-2012, 01:18 AM
RE: Majestic 181 - by Doug Houston - 03-25-2012, 09:33 PM
RE: Majestic 181 - by Jayce - 03-25-2012, 10:51 PM
RE: Majestic 181 - by Arran - 03-26-2012, 12:05 AM
RE: Majestic 181 - by Doug Houston - 03-26-2012, 11:14 PM
RE: Majestic 181 - by TA Forbes - 03-27-2012, 01:54 PM
RE: Majestic 181 - by codefox1 - 03-27-2012, 09:03 PM
RE: Majestic 181 - by Doug Houston - 04-05-2012, 11:19 PM
RE: Majestic 181 - by Arran - 03-27-2012, 07:43 PM
RE: Majestic 181 - by Jayce - 03-29-2012, 07:56 PM
RE: Majestic 181 - by Arran - 04-03-2012, 11:30 PM
RE: Majestic 181 - by Doug Houston - 03-29-2012, 11:53 PM
RE: Majestic 181 - by Jayce - 04-04-2012, 12:39 AM
RE: Majestic 181 - by codefox1 - 04-04-2012, 02:57 AM
RE: Majestic 181 - by Arran - 04-05-2012, 01:26 AM
There are currently 10539 online users. [Complete List]
» 3 Member(s) | 10536 Guest(s)
