37-650....more, yet.
Hello, Doug: I have a 38-5 that will only work with a 5Y3. It had a 5U4 installed when I got it. I have no Idea how it was modified.....
37-650....more, yet. - by Doug Houston - 03-03-2012, 01:17 AM
RE: 37-650....more, yet. - by Arran - 03-03-2012, 02:58 AM
RE: 37-650....more, yet. - by Ron Ramirez - 03-07-2012, 07:42 PM
RE: 37-650....more, yet. - by Doug Houston - 03-25-2012, 09:17 PM
RE: 37-650....more, yet. - by Arran - 03-25-2012, 10:57 PM
RE: 37-650....more, yet. - by TA Forbes - 03-25-2012, 11:43 PM
RE: 37-650....more, yet. - by Doug Houston - 03-26-2012, 12:04 AM
RE: 37-650....more, yet. - by Arran - 03-26-2012, 12:35 AM
RE: 37-650....more, yet. - by Ron Ramirez - 03-26-2012, 05:51 AM
RE: 37-650....more, yet. - by Doug Houston - 03-26-2012, 10:53 PM
RE: 37-650....more, yet. - by Ron Ramirez - 03-27-2012, 05:35 AM
RE: 37-650....more, yet. - by TA Forbes - 03-27-2012, 01:46 PM
Philco 91 Tuning Condenser
There are currently 4998 online users. [Complete List]
» 2 Member(s) | 4996 Guest(s)
