RE-Stuffing Model 90 Tone Caps?
(03-26-2012, 12:35 PM)Pepperoni Wrote:  You know I just jumped into it last night and I believe it's gonna be a piece of cake. It's a small metal can that has ends that can be folded open and the old rectangle of tar and caps just pops out. Of course you have to cut the three (3) cap wires that go the the switch contacts themselves. I'll try to post some pics.
Pepper
I open the can just enough to let the slug fall out with a heat gun on low. Re-stuff with your fav. caps.
Chuck
RE-Stuffing Model 90 Tone Caps? - by Pepperoni - 03-25-2012, 11:35 PM
RE: RE-Stuffing Model 90 Tone Caps? - by Chuck Schwark - 03-26-2012, 01:52 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7095 online users. [Complete List]
» 1 Member(s) | 7094 Guest(s)
