replacement or template for "dial pointer" philco 84b
thanks ron for this info on dial pointer...i hope i can make one....
STEVE ADORNO
nylatinrock@yahoo.com
Onroda MusicWorks - http://www.amazon.com/Seguida/e/B001LHDMN8
RE: replacement or template for "dial pointer" philco 84b - by seguida - 03-27-2012, 08:37 AM
The speaker table error?
Philco 70 antenna lead
