Into the fray with a 116X
If you can handle a 100 pF 200v cap in that application, mouser has their p/n 581-SA102A101JAR (0.19 each) or 80-C410C101J2G (0.58 each) note they are ceramic. They can get 110 pF 400V poly caps at 68 cents each, but it is a long lead time.....And you have to order 3800 of them Icon_sad
If you want radial leads there are a ton o silver micas available at 500V
When I run into this I order a few and some .01 .047 etc for stock so I dont feel to bad about the freight.
John
Las Vegas, NV USA
Into the fray with a 116X - by rocketeer - 03-26-2012, 05:00 PM
RE: Into the fray with a 116X - by TA Forbes - 03-26-2012, 05:32 PM
RE: Into the fray with a 116X - by rocketeer - 03-26-2012, 06:15 PM
RE: Into the fray with a 116X - by rocketeer - 03-27-2012, 09:29 PM
RE: Into the fray with a 116X - by Arran - 03-27-2012, 09:39 PM
RE: Into the fray with a 116X - by rocketeer - 03-27-2012, 11:11 PM
RE: Into the fray with a 116X - by LASJayhawk - 03-28-2012, 12:14 AM
RE: Into the fray with a 116X - by rocketeer - 03-28-2012, 09:11 AM
RE: Into the fray with a 116X - by Chuck Schwark - 03-28-2012, 09:54 AM
RE: Into the fray with a 116X - by rocketeer - 03-28-2012, 08:56 PM
RE: Into the fray with a 116X - by rocketeer - 04-06-2012, 09:32 PM
RE: Into the fray with a 116X - by rocketeer - 04-12-2012, 07:12 PM
RE: Into the fray with a 116X - by TA Forbes - 04-13-2012, 09:47 AM
RE: Into the fray with a 116X - by rocketeer - 04-13-2012, 07:26 PM
RE: Into the fray with a 116X - by Chuck Schwark - 04-13-2012, 09:21 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6843 online users. [Complete List]
» 1 Member(s) | 6842 Guest(s)
