RE-Stuffing Model 90 Tone Caps?
(03-27-2012, 12:22 PM)Pepperoni Wrote:  Also on this Philco 90... What is the polarity of the 1.0ufd #30 cap? I ask because it's in parallel with a 70K resistor to ground but the other end goes through a 25K resistor, through the 3 section resistor to the CT of the high voltage output which I thought was the most negative part of the radio. So which end goes to chassis ground? + or -? Assuming this is a lytic cap.
Got the cap figured out.
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
RE-Stuffing Model 90 Tone Caps? - by Pepperoni - 03-25-2012, 11:35 PM
RE: RE-Stuffing Model 90 Tone Caps? - by Pepperoni - 03-28-2012, 11:51 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7329 online users. [Complete List]
» 3 Member(s) | 7326 Guest(s)
