Philco 37-84
(03-27-2012, 11:31 PM)tab10672 Wrote:  It may have been another production run or code than that of the schematic you have, they changed many things as a radio was produced as to repair issues that would come up.
True. I'm going with a 240K resistor.
Philco 37-84 - by Art Hoch - 03-23-2012, 11:04 PM
RE: Philco 37-84 - by 7estatdef - 03-23-2012, 11:26 PM
RE: Philco 37-84 - by AI2V - 03-27-2012, 03:10 PM
RE: Philco 37-84 - by Art Hoch - 03-27-2012, 08:06 PM
RE: Philco 37-84 - by codefox1 - 03-27-2012, 08:54 PM
RE: Philco 37-84 - by tab10672 - 03-27-2012, 11:31 PM
RE: Philco 37-84 - by Art Hoch - 03-28-2012, 08:39 PM
RE: Philco 37-84 - by Art Hoch - 03-29-2012, 06:41 PM
RE: Philco 37-84 - by 7estatdef - 03-29-2012, 07:10 PM
RE: Philco 37-84 - by Art Hoch - 04-13-2012, 12:42 PM
RE: Philco 37-84 - by Art Hoch - 04-23-2012, 11:11 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7680 online users. [Complete List]
» 3 Member(s) | 7677 Guest(s)
