  • 1 Vote(s) - 4 Average
Philco 37-116X What's The Price Point?
I appreciate all the input from you guys. Probably the problem lies with me. TAForbes, you are correct....bottom line is I don't want the set bad enough. I didn't miss your point, I happen to be one of those people who doesn't like being told what a great bargain I am getting, which is how this guy came across. I spoke to both he and his wife at different times on the phone. She was extremely polite and very helpful. Just the tone of his voice didn't set me up well. So you are correct I didn't want the 116 bad enough to deal with the seller. Sometimes being a stubborn Norwegian has its drawbacks.
Gene
RE: Philco 37-116X What's The Price Point? - by Gene Pederson - 03-28-2012, 08:52 PM
Philco 91 Tuning Condenser
