Philco 37-84
Radio has all new caps and resistors replaced if out-of-tolerance. However, radio not playing yet ---- and a wire-wound 325 ohm resistor (#30 on schem) connected to transformer gets VERY hot. Is this a sign of a bad transformer?
Philco 37-84 - by Art Hoch - 03-23-2012, 11:04 PM
RE: Philco 37-84 - by 7estatdef - 03-23-2012, 11:26 PM
RE: Philco 37-84 - by AI2V - 03-27-2012, 03:10 PM
RE: Philco 37-84 - by Art Hoch - 03-27-2012, 08:06 PM
RE: Philco 37-84 - by codefox1 - 03-27-2012, 08:54 PM
RE: Philco 37-84 - by tab10672 - 03-27-2012, 11:31 PM
RE: Philco 37-84 - by Art Hoch - 03-28-2012, 08:39 PM
RE: Philco 37-84 - by Art Hoch - 03-29-2012, 06:41 PM
RE: Philco 37-84 - by 7estatdef - 03-29-2012, 07:10 PM
RE: Philco 37-84 - by Art Hoch - 04-13-2012, 12:42 PM
RE: Philco 37-84 - by Art Hoch - 04-23-2012, 11:11 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6867 online users. [Complete List]
» 1 Member(s) | 6866 Guest(s)
