RE-Stuffing Model 90 Tone Caps?
Thanks guys! Got it.
I pulled the schematic from philcoradio.com on this Philco 90 with all of the component values added. My Philco 90 (single 47 output) has a 250K volume pot in it and the part number 5366 is on the volume control which matches the parts list. But the schematic calls out a .5 meg pot. Is this a discrepancy on the edited schematic or is my volume pot not functioning properly? It seems to be functioning properly with my Fluke 179 hooked up to the CT and each leg but reads 250K across it.
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
RE-Stuffing Model 90 Tone Caps? - by Pepperoni - 03-25-2012, 11:35 PM
RE: RE-Stuffing Model 90 Tone Caps? - by Pepperoni - 03-29-2012, 07:08 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7489 online users. [Complete List]
» 3 Member(s) | 7486 Guest(s)
