42-123 output trans. replacement
Does anyone know of a replacement output trans, new or interchangable from another model that would work in a 42-123? 900/1100 CT.
Thanks, Todd
42-123 output trans. replacement - by tab10672 - 03-30-2012, 03:24 PM
The speaker table error?
Philco 70 antenna lead
