? WHAT MODEL is this Cabinet?
(03-30-2012, 10:00 PM)Ron Ramirez Wrote:  I just received a photo of the same cabinet (with doors closed).
Looks like a early to mid 1950s Philco TV cabinet to me.
THAT'S what I said she instead a Radio was in it. She could not provide a model number and when i ask about the knobs she they wen under the bars like nothing i have seen.
? WHAT MODEL is this Cabinet? - by Bradley Rush - 03-30-2012, 09:46 PM
RE: ? WHAT MODEL is this Cabinet? - by Bradley Rush - 03-30-2012, 10:08 PM
Philco 91 Tuning Condenser
