Admiral/Continental 960-8K
Gene: I have a Belknap that bears a remarkable resemblance to your Admiral/Continental. Will send you some pics. What is the tube lineup of your set? Also, would you mind posting a pic of the chassis.
I attributed my chassis to Warwick.....
Admiral/Continental 960-8K - by Gene Pederson - 03-30-2012, 01:38 PM
RE: Admiral/Continental 8KU - by rghines1 - 03-30-2012, 04:05 PM
RE: Admiral/Continental 8KU - by codefox1 - 03-31-2012, 07:24 PM
RE: Admiral/Continental 960-8K - by Jayce - 03-30-2012, 05:20 PM
RE: Admiral/Continental 960-8K - by TA Forbes - 03-30-2012, 11:58 PM
RE: Admiral/Continental 960-8K - by 7estatdef - 03-31-2012, 05:52 PM
RE: Admiral/Continental 960-8K - by Gene Pederson - 04-01-2012, 10:19 PM
RE: Admiral/Continental 960-8K - by Arran - 04-01-2012, 11:52 PM
RE: Admiral/Continental 960-8K - by TA Forbes - 04-02-2012, 12:03 PM
There are currently 10283 online users. [Complete List]
» 2 Member(s) | 10281 Guest(s)
