Philco model 65
You can probably make most of the chassis/speakers work that had the old knob arrangement like your 65. Main diff would be the 111/112 and model 15 chassis, reason is the dial scale is wider and is blocked out by the narrow-er escutchion window.
Philco model 65 - by w4rtc - 03-31-2012, 02:48 PM
RE: Philco model 65 - by tab10672 - 03-31-2012, 05:08 PM
RE: Philco model 65 - by 7estatdef - 03-31-2012, 05:29 PM
RE: Philco model 65 - by TA Forbes - 03-31-2012, 11:00 PM
Philco 91 Tuning Condenser
There are currently 4029 online users. [Complete List]
» 1 Member(s) | 4028 Guest(s)
