Philco 42 345T
(04-01-2012, 12:39 PM)Ron Ramirez Wrote:  I believe that is probably the external antenna jack. These two pages will explain everything:
http://philcoradio.com/phorum/showthread.php?tid=1472
http://www.philcoradio.com/phorum/showth...p?tid=2599
Thanks Ron:
Very interesting, this set is very sensitive and pulls in a lot of stations as is. I can imagine what I could get with a good longwire. The internal antenna looks like copper plumbing, pretty unique. I have only seen this style internal in Philco's.
Thanks much.
Philco 42 345T - by Paul Philco322 - 04-01-2012, 11:33 AM
RE: Philco 42 345T - by Ron Ramirez - 04-01-2012, 12:39 PM
RE: Philco 42 345T - by Paul Philco322 - 04-01-2012, 05:12 PM
RE: Philco 42 345T - by Michael Dennis - 04-02-2012, 08:40 PM
RE: Philco 42 345T - by Paul Philco322 - 04-03-2012, 10:00 PM
RE: Philco 42 345T - by Michael Dennis - 04-03-2012, 11:24 PM
Philco 91 Tuning Condenser
There are currently 3388 online users. [Complete List]
» 2 Member(s) | 3386 Guest(s)
