A Magnavox Thing. Bill Cahill Look Here
(03-30-2012, 12:13 AM)Doug Houston Wrote:  http://cgi.ebay.com/230769454047
I know that this is probably the wrong place for it, but Bill Cahill might want to see this.
Man that thing is gorgeous. Would be a deal at $30.00. I'm sure final will be around $100.00 tho.
RE: A Magnavox Thing. Bill Cahill Look Here - by FXpert - 04-02-2012, 07:41 AM
Philco 91 Tuning Condenser
There are currently 8118 online users. [Complete List]
» 2 Member(s) | 8116 Guest(s)
