Silvertone 1968
I finally found a picture of one of these and I like it! I have the smaller, 8 tube sibling to this radio in my collection and it has always been a nice set. Odd that I rarely run across Silvertone radios around here.
Silvertone 1968 - by TA Forbes - 03-29-2012, 10:45 PM
RE: Silvertone 1968 - by Gene Pederson - 04-01-2012, 10:28 PM
RE: Silvertone 1968 - by Arran - 04-01-2012, 11:48 PM
RE: Silvertone 1968 - by TA Forbes - 04-02-2012, 11:57 AM
RE: Silvertone 1968 - by Jayce - 04-02-2012, 09:12 PM
RE: Silvertone 1968 - by TA Forbes - 04-04-2012, 09:49 AM
There are currently 10757 online users. [Complete List]
» 1 Member(s) | 10756 Guest(s)
