Scored a 41-316RX !
#31
I'm in the home stretch on the cabinet. This bottom area was so bad (probably from years of getting kicked) I decided to replace the veneer.
[Image: http://farm8.staticflickr.com/7278/68968...a49670.jpg]
That should do it.
[Image: http://farm8.staticflickr.com/7060/70429...b9af70.jpg]
Scored a 41-316RX ! - by Bob Andersen - 03-07-2012, 11:24 PM
RE: Scored a 41-316RX ! - by Jayce - 03-08-2012, 12:13 AM
RE: Scored a 41-316RX ! - by Arran - 03-08-2012, 03:56 AM
RE: Scored a 41-316RX ! - by Arran - 03-08-2012, 01:16 AM
RE: Scored a 41-316RX ! - by TA Forbes - 03-08-2012, 05:08 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-08-2012, 05:47 PM
RE: Scored a 41-316RX ! - by Ron Ramirez - 03-08-2012, 08:37 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-08-2012, 09:25 PM
RE: Scored a 41-316RX ! - by Arran - 03-08-2012, 10:40 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-09-2012, 05:59 PM
RE: Scored a 41-316RX ! - by Arran - 03-09-2012, 09:42 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-09-2012, 11:58 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-10-2012, 08:47 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-11-2012, 03:13 AM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-11-2012, 03:27 AM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-16-2012, 05:04 PM
RE: Scored a 41-316RX ! - by Ron Ramirez - 03-16-2012, 07:10 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-16-2012, 11:52 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-19-2012, 03:30 PM
RE: Scored a 41-316RX ! - by Doug Houston - 03-19-2012, 07:59 PM
RE: Scored a 41-316RX ! - by Arran - 03-20-2012, 01:02 AM
RE: Scored a 41-316RX ! - by Ron Ramirez - 03-19-2012, 10:05 PM
RE: Scored a 41-316RX ! - by Arran - 03-20-2012, 01:12 AM
RE: Scored a 41-316RX ! - by TA Forbes - 03-20-2012, 10:56 AM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-19-2012, 11:37 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-21-2012, 12:17 AM
RE: Scored a 41-316RX ! - by Arran - 03-21-2012, 08:47 PM
RE: Scored a 41-316RX ! - by w4rtc - 03-21-2012, 12:05 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-21-2012, 01:23 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-22-2012, 05:56 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 04-03-2012, 04:10 PM
RE: Scored a 41-316RX ! - by Ron Ramirez - 04-03-2012, 09:33 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 06-18-2015, 04:41 PM
RE: Scored a 41-316RX ! - by Warren - 06-18-2015, 10:42 PM
Users browsing this thread: 22 Guest(s)
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
There are currently 3505 online users. [Complete List]
» 2 Member(s) | 3503 Guest(s)
