All Wave Aerial Transmission Line ?
Thanks, Ron ! It's really interesting to learn what this thing was / what they were trying to do. In my situation I think I'd be better off making up a basic loop antenna - should be a fun project.
Chris
RE: All Wave Aerial Transmission Line ? - by Chris Cusick - 04-05-2012, 10:05 AM
Philco 91 Tuning Condenser
There are currently 5834 online users. [Complete List]
» 3 Member(s) | 5831 Guest(s)
