When Is A Restoration Really A Restoration?
Pepperoni--you sure aren't any "baloney"!! I found a car upholsterer in my neighborhood and he's ordering me a large piece of the door backing material (at least 42 by 35). Not only is it the perfect thickness (1/8th inch) but is the right color (tan) and it will be easy to scribe out the appropriate holes. Thanks...you have surely saved me lots of money. Now if I could only figure out how to spray the PHILCO name on the back.....
RE: When Is A Restoration Really A Restoration? - by Sam samuelian - 04-06-2012, 11:03 AM
Users browsing this thread: 13 Guest(s)
The speaker table error?
Philco 70 antenna lead
There are currently 7118 online users. [Complete List]
» 2 Member(s) | 7116 Guest(s)
