Philco 38-60
Not sure if it's a different part, or maybe a missprint or smudge on your parts list, but Chuck has one listed on his site labeled 8328-su. Surf on over to the Philco repair bench and take a peek in the parts value section.
Philco 38-60 - by fixinmyphilco - 03-25-2012, 02:46 PM
RE: Philco 38-60 - by tab10672 - 03-25-2012, 03:27 PM
RE: Philco 38-60 - by TA Forbes - 03-25-2012, 11:47 PM
RE: Philco 38-60 - by fixinmyphilco - 03-26-2012, 06:37 PM
RE: Philco 38-60 - by fixinmyphilco - 04-06-2012, 07:22 PM
RE: Philco 38-60 - by Dave - 04-06-2012, 10:00 PM
RE: Philco 38-60 - by fixinmyphilco - 04-07-2012, 02:54 AM
RE: Philco 38-60 - by Dave - 04-07-2012, 10:41 AM
RE: Philco 38-60 - by TA Forbes - 04-07-2012, 10:53 AM
RE: Philco 38-60 - by fixinmyphilco - 04-12-2012, 05:29 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7066 online users. [Complete List]
» 1 Member(s) | 7065 Guest(s)
