38-116 Question
(04-08-2012, 07:37 AM)Ron Ramirez Wrote:  Oh yes, there was a 38-116 Code 121...it used the RF deck leftover from the 37-116/37-675/37-690 production.
The 38-116 Code 125 (as well as the 38-690 Code 125) use a different RF unit with fewer trimmers.
It could very well be that Philco put a few too many Code 121 labels on their cabinets. That is, they ran out of Code 121 chassis before they thought they would and began installing Code 125 chassis into cabinets that may have still had a Code 121 label. It wouldn't be the first time Philco made an error in labeling.
The blue labels you speak of were usually in the cabinets from 1937 on, but were still occasionally found on the chassis. Between 1935 and 1936 they were on the chassis. In 1934 and prior, they used gold labels placed on the chassis. And to make things more confusing, Philco continued to use gold labels through the 1936 season on sets such as the 60 and 89.
Thanks Ron. That makes sense as I have seen the blue labels on my older sets and have a 60 with the gold one.
The guy I bought this from had it in the basement for a long time. Fortunately there is very little rust and it cleaned up well yesterday. Hopefully the cabinet will finish well, it has a little water damage on the bottom. I notice that someone pulled a few of the tube bases to put a couple of metal tubes in. This must have been fairly common as I have another 38-116 which has several bases removed. My 38-690 also has one removed and a GT in its place.
Is there a good source for these bases? Thats the only thing lacking originality.
38-116 Question - by SteveJB - 04-07-2012, 10:27 AM
RE: 38-116 Question - by 7estatdef - 04-07-2012, 10:34 PM
RE: 38-116 Question - by Ron Ramirez - 04-08-2012, 07:37 AM
RE: 38-116 Question - by SteveJB - 04-08-2012, 08:33 PM
RE: 38-116 Question - by 7estatdef - 04-08-2012, 10:35 PM
RE: 38-116 Question - by SteveJB - 04-08-2012, 11:37 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6892 online users. [Complete List]
» 1 Member(s) | 6891 Guest(s)
