Philco 84
(04-08-2012, 04:58 PM)7estatdef Wrote:
(04-08-2012, 11:08 AM)Jim Dutridge Wrote:  Well now I'm bummed. The oscillator coil has both windings open. This will take some patience.
Are you sure? You know one of the lugs is a dummy. Use your ohm meter with one lead connected to the bracket, the other touch to the lugs. If the coils are good should show resistance on two lugs. If it show resistance on one probably the feedback winding is the open one. Never seen one with both open. Is a first time for everything.
Yep, both coils read open to the common lug. I unwound them and both had the dreaded green disease. Primary is a 17 turn winding while the secondary is a 93 turn winding. The open in the secondary was about 60 turns in.
Philco 84 - by Jim Dutridge - 04-03-2012, 03:39 PM
RE: Philco 84 - by Ron Ramirez - 04-03-2012, 04:18 PM
RE: Philco 84 - by Jim Dutridge - 04-03-2012, 04:29 PM
RE: Philco 84 - by Art Hoch - 04-03-2012, 08:10 PM
RE: Philco 84 - by Jim Dutridge - 04-03-2012, 09:04 PM
RE: Philco 84 - by Ron Ramirez - 04-03-2012, 09:31 PM
RE: Philco 84 - by Jim Dutridge - 04-05-2012, 05:11 PM
RE: Philco 84 - by Art Hoch - 04-05-2012, 09:49 PM
RE: Philco 84 - by Jim Dutridge - 04-07-2012, 01:09 PM
RE: Philco 84 - by 7estatdef - 04-07-2012, 02:09 PM
RE: Philco 84 - by Jim Dutridge - 04-08-2012, 10:48 AM
RE: Philco 84 - by 7estatdef - 04-08-2012, 04:48 PM
RE: Philco 84 - by Jim Dutridge - 04-08-2012, 11:08 AM
RE: Philco 84 - by 7estatdef - 04-08-2012, 04:58 PM
RE: Philco 84 - by Jim Dutridge - 04-09-2012, 09:56 AM
RE: Philco 84 - by 7estatdef - 04-09-2012, 01:58 PM
RE: Philco 84 - by Jim Dutridge - 04-09-2012, 02:19 PM
RE: Philco 84 - by 7estatdef - 04-09-2012, 03:38 PM
RE: Philco 84 - by Jim Dutridge - 04-10-2012, 04:23 PM
RE: Philco 84 - by 7estatdef - 04-10-2012, 07:28 PM
RE: Philco 84 - by Jim Dutridge - 04-11-2012, 05:47 PM
RE: Philco 84 - by Jim Dutridge - 04-15-2012, 12:18 PM
RE: Philco 84 - by 7estatdef - 04-15-2012, 03:31 PM
RE: Philco 84 - by Jim Dutridge - 04-15-2012, 06:37 PM
RE: Philco 84 - by Jim Dutridge - 05-11-2012, 04:10 PM
RE: Philco 84 - by 7estatdef - 05-13-2012, 08:42 AM
RE: Philco 84 - by Jim Dutridge - 05-15-2012, 03:31 PM
RE: Philco 84 - by Jim Dutridge - 05-31-2012, 04:34 PM
RE: Philco 84 - by 7estatdef - 05-31-2012, 08:12 PM
RE: Philco 84 - by Jim Dutridge - 05-31-2012, 11:06 PM
RE: Philco 84 - by 7estatdef - 06-01-2012, 06:35 AM
RE: Philco 84 - by Jim Dutridge - 06-01-2012, 03:20 PM
RE: Philco 84 - by 7estatdef - 06-01-2012, 03:40 PM
RE: Philco 84 - by Jim Dutridge - 06-04-2012, 03:55 PM
RE: Philco 84 - by Jim Dutridge - 06-12-2012, 05:37 PM
RE: Philco 84 - by 7estatdef - 06-13-2012, 08:59 PM
RE: Philco 84 - by Jim Dutridge - 06-15-2012, 04:00 PM
RE: Philco 84 - by Jim Dutridge - 10-14-2014, 06:19 PM
RE: Philco 84 - by morzh - 10-14-2014, 07:27 PM
RE: Philco 84 - by Jim Dutridge - 10-14-2014, 08:01 PM
RE: Philco 84 - by morzh - 10-14-2014, 10:10 PM
There are currently 9245 online users. [Complete List]
» 2 Member(s) | 9243 Guest(s)
