Philco alignment adapter?
Right off hand I would say it is just what you said, an adapter to allow for access to tube pins from the top of the chassis. By the time the 1232 tube was in use, no (loctal) tubes had the grid located at the top of the tube.
Philco alignment adapter? - by DonS - 04-09-2012, 08:12 AM
RE: Philco alignment adapter? - by TA Forbes - 04-09-2012, 11:22 AM
Philco 91 Tuning Condenser
There are currently 5086 online users. [Complete List]
» 1 Member(s) | 5085 Guest(s)
