Philco 18 micamold question
(04-09-2012, 11:58 AM)DKinYORKpa Wrote:  I'm dealing with some factory changes along with some discrepancies. A micamold cap is not on the Philco 18 drawing, but it is on the Philco 14 drawing. It's listed as .006 on that parts list and a factory change (Philco 18) lists it as .0025 but the markings on it are brown red brown. Would the markings indicate 120 mmfd?
Where in the circuit is it??
Philco 18 micamold question - by DKinYORKpa - 04-09-2012, 11:58 AM
RE: Philco 18 micamold question - by 7estatdef - 04-09-2012, 01:50 PM
RE: Philco 18 micamold question - by DKinYORKpa - 04-09-2012, 02:18 PM
RE: Philco 18 micamold question - by DKinYORKpa - 04-09-2012, 05:02 PM
RE: Philco 18 micamold question - by exray - 04-10-2012, 08:23 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7765 online users. [Complete List]
» 2 Member(s) | 7763 Guest(s)
