Philco 90 Tube Shield Question
Be interesting to put a scope on the audio output to be sure it's not oscillating at ultrasonic frequencies or higher that would be inaudible.
Potential risk of capacitive coupling between the two 27 tubes and audio output stage.
Philco 90 Tube Shield Question - by Geoff - 04-09-2012, 03:13 PM
RE: Philco 90 Tube Shield Question - by tab10672 - 04-09-2012, 04:41 PM
RE: Philco 90 Tube Shield Question - by rghines1 - 04-09-2012, 06:37 PM
RE: Philco 90 Tube Shield Question - by Geoff - 04-09-2012, 06:51 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7168 online users. [Complete List]
» 3 Member(s) | 7165 Guest(s)
