  • 1 Vote(s) - 5 Average
philco 48-1270 burning out r315/ updates
I took the can off and right away the ohms went up to the meg range. I tried it and had reception right away but after 30 seconds it went out with a zap noise out the speaker. No smoke just a noise like zzz. It still actually has sound but with the volume up all the way I can still hear stations. Then I unplugged and checked that can again. Seems the wiring is fluctuating a lot dropping all the way down to 25,000 ohms . I will remove all the wires and get a good look under the terminal lug in the chassis that its connected to there are other things attached there too and its a mess but thanks for the help so far
RE: philco 48-1270 burning out r315 - by John R - 04-12-2012, 12:47 PM
RE: philco 48-1270 burning out r315 - by magicclocks - 04-12-2012, 08:09 PM
RE: philco 48-1270 burning out r315 - by John R - 04-13-2012, 12:37 AM
RE: philco 48-1270 burning out r315 - by codefox1 - 04-13-2012, 02:16 AM
RE: philco 48-1270 burning out r315 - by rghines1 - 04-14-2012, 09:06 AM
RE: philco 48-1270 burning out r315 - by Arran - 04-14-2012, 11:38 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7131 online users. [Complete List]
» 2 Member(s) | 7129 Guest(s)
