New to this site and have a Philco 20 question.
Hi Jonathan,
The trf radio has no IF's or avc. Icon_cry It amplifies the rf on the whole band through- out the radio to the detector/first audio amplifier. That is why you get "blaring" on strong signals and have to turn up the volume on weak signals (no avc). Have you recaped the radio yet? A good recapping might be in order. You can find the schematic here. http://www.nostalgiaair.org/PagesByModel...029582.pdf
Hope this helps
New to this site and have a Philco 20 question. - by Guest - 12-01-2006, 10:17 PM
[No subject] - by Terry Burns - 12-06-2006, 09:27 AM
[No subject] - by Ron Ramirez - 12-06-2006, 10:23 AM
[No subject] - by Guest - 12-07-2006, 10:17 PM
