Model 90 Stuck At One Volume Level
Yeah morzh I drilled that rivet out during the resto because it looked a little corroded. I reused the ground strap, it's good but I replaced the rivet with a small screw, lockwasher and nut. My lead resistance is .1 ohms and the volume ground reads .1 ohms.
It's late here so I enlarged two more copies of the schematic to 11X17 and in the morning I'm gonna go through the whole circuit and highlight each section as I go. This will be the third time. If I'm missing something I must be blind. I can ground the grid on the Det. Amp. and I still have volume. So I still have an audio signal going into the 1st AF from somewhere.
Appreciate the help from all of you! Let you know what I do or don't find.
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
Model 90 Stuck At One Volume Level - by Pepperoni - 04-12-2012, 04:54 PM
RE: Model 90 Stuck At One Volume Level - by morzh - 04-12-2012, 10:19 PM
RE: Model 90 Stuck At One Volume Level - by Pepperoni - 04-12-2012, 10:44 PM
RE: Model 90 Stuck At One Volume Level - by morzh - 04-14-2012, 03:44 PM
RE: Model 90 Stuck At One Volume Level - by morzh - 04-14-2012, 03:52 PM
RE: Model 90 Stuck At One Volume Level - by morzh - 04-14-2012, 07:16 PM
RE: Model 90 Stuck At One Volume Level - by morzh - 04-14-2012, 09:51 PM
RE: Model 90 Stuck At One Volume Level - by morzh - 04-15-2012, 01:04 PM
RE: Model 90 Stuck At One Volume Level - by morzh - 04-15-2012, 02:26 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6834 online users. [Complete List]
» 1 Member(s) | 6833 Guest(s)
