  • 1 Vote(s) - 5 Average
philco 48-1270 burning out r315/ updates
Sort of an odd thing while I wait for new cap kit to come before trying again when I test for shorts to some places . I get high meg ohms but if I lift off and check again a seconds later it will be much lower ohms and again if I lift off again dropping each time. If I wait for 10 seconds or so and try again it will be back up to meg ohms ,. Question is. Is this the caps all around leaking or my meter ?
RE: philco 48-1270 burning out r315 - by John R - 04-12-2012, 12:47 PM
RE: philco 48-1270 burning out r315 - by John R - 04-13-2012, 12:37 AM
RE: philco 48-1270 burning out r315 - by codefox1 - 04-13-2012, 02:16 AM
RE: philco 48-1270 burning out r315 - by magicclocks - 04-13-2012, 09:15 PM
RE: philco 48-1270 burning out r315 - by rghines1 - 04-14-2012, 09:06 AM
RE: philco 48-1270 burning out r315 - by Arran - 04-14-2012, 11:38 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6936 online users. [Complete List]
» 1 Member(s) | 6935 Guest(s)
