Missing Spring for Tuning
Ace Hardware is another Good option for a lot of tiny hardware like the springs. I have improvised using them a few times. You can also find a few springs in old cassette players and video players. The biggest problem for me is tying the knots on the string. What I have been thinking of doing is to use a pair of hemostat clamps to hold the loop and apply a glob of Super glue. The reason is you have to have some tension whilst doing this on the dial spring so it wont slip or be loose and sloppy.
Missing Spring for Tuning - by FearOfMusic - 04-16-2012, 01:06 AM
RE: Missing Spring for Tuning - by Chuck Schwark - 04-16-2012, 10:23 AM
RE: Missing Spring for Tuning - by Sparks_Radio - 04-16-2012, 12:58 PM
RE: Missing Spring for Tuning - by FearOfMusic - 04-16-2012, 10:33 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6858 online users. [Complete List]
» 1 Member(s) | 6857 Guest(s)
