Philco 37-84--no sound
(04-16-2012, 05:32 PM)sjhs1962 Wrote:  Riders shows a plate voltage of 40 Vdc on the plate of 2nd detector 1st audio. Is this correct? My radio is showing a 230 Vdc???
I've got a better question. How come you have 230v when you should have 40v??? Is the cathode open? Filament good? Tube doesn't seem to be conducting.
Philco 37-84--no sound - by sjhs1962 - 04-08-2012, 04:50 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-08-2012, 10:43 PM
RE: Philco 37-84--no sound - by sjhs1962 - 04-09-2012, 10:40 AM
RE: Philco 37-84--no sound - by 7estatdef - 04-09-2012, 01:47 PM
RE: Philco 37-84--no sound - by sjhs1962 - 04-16-2012, 05:32 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-16-2012, 09:31 PM
RE: Philco 37-84--no sound - by sjhs1962 - 04-17-2012, 02:38 PM
RE: Philco 37-84--no sound - by codefox1 - 04-18-2012, 08:40 PM
RE: Philco 37-84--no sound - by morzh - 04-16-2012, 06:09 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-18-2012, 08:36 AM
RE: Philco 37-84--no sound - by sjhs1962 - 04-18-2012, 02:11 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-18-2012, 05:34 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-19-2012, 04:49 PM
RE: Philco 37-84--no sound - by sjhs1962 - 04-21-2012, 01:18 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-22-2012, 07:56 PM
RE: Philco 37-84--no sound - by sjhs1962 - 05-08-2012, 10:45 AM
RE: Philco 37-84--no sound - by codefox1 - 05-08-2012, 11:15 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6945 online users. [Complete List]
» 1 Member(s) | 6944 Guest(s)
