Philco 37-84--no sound
(04-18-2012, 02:11 PM)sjhs1962 Wrote:
(04-18-2012, 08:36 AM)7estatdef Wrote:  So what happens when you inject a 470kc signal into the cap of the mixer tube? Do the IF adjustments have a nice peak?
Not really good at alignment until I get a station coming thru...and finally one came thru and I was able to adjust the trimmers and voila it came alive across the dial. I get a little static between stations but station come in strong! Volume control doesn't work real well...but actually good enough ...It must short out except at the very loudest with miniscule adjustment that is....good enough. I guess I could try to open it up and clean the control. Thanks to all for help and support!
A couple of things... You won't be able the best of performance until till the IF is peaked up on frequency (470kc). Can't fudge it by peaking all the trimmers for max signal on the BC band!!! No no no!
Volume control won't work properly without a good ground connected to the chassis. The set needs a good earth ground to work against the antenna through the volume control.
Philco 37-84--no sound - by sjhs1962 - 04-08-2012, 04:50 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-08-2012, 10:43 PM
RE: Philco 37-84--no sound - by sjhs1962 - 04-09-2012, 10:40 AM
RE: Philco 37-84--no sound - by 7estatdef - 04-09-2012, 01:47 PM
RE: Philco 37-84--no sound - by sjhs1962 - 04-16-2012, 05:32 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-16-2012, 09:31 PM
RE: Philco 37-84--no sound - by sjhs1962 - 04-17-2012, 02:38 PM
RE: Philco 37-84--no sound - by codefox1 - 04-18-2012, 08:40 PM
RE: Philco 37-84--no sound - by morzh - 04-16-2012, 06:09 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-18-2012, 08:36 AM
RE: Philco 37-84--no sound - by sjhs1962 - 04-18-2012, 02:11 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-18-2012, 05:34 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-19-2012, 04:49 PM
RE: Philco 37-84--no sound - by sjhs1962 - 04-21-2012, 01:18 PM
RE: Philco 37-84--no sound - by 7estatdef - 04-22-2012, 07:56 PM
RE: Philco 37-84--no sound - by sjhs1962 - 05-08-2012, 10:45 AM
RE: Philco 37-84--no sound - by codefox1 - 05-08-2012, 11:15 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6645 online users. [Complete List]
» 1 Member(s) | 6644 Guest(s)
