Old Russian / Soviet tube radios
The only Russian stuff I am into is firearms. Early in my USMC career I learned that you could drop an AK 47 in the mud and still reasonably expect it to work when you needed it to. This provided me with great comfort and recompense when in an otherwise extremely elevated state of awareness.
Old Russian / Soviet tube radios - by morzh - 04-19-2012, 01:56 PM
RE: Old Russian / Soviet tube radios - by Arran - 04-20-2012, 12:30 AM
RE: Old Russian / Soviet tube radios - by morzh - 04-20-2012, 12:45 PM
RE: Old Russian / Soviet tube radios - by Arran - 04-20-2012, 11:14 PM
RE: Old Russian / Soviet tube radios - by TA Forbes - 04-20-2012, 07:36 PM
RE: Old Russian / Soviet tube radios - by morzh - 04-20-2012, 08:35 PM
RE: Old Russian / Soviet tube radios - by morzh - 04-21-2012, 01:51 PM
RE: Old Russian / Soviet tube radios - by morzh - 04-21-2012, 02:30 PM
RE: Old Russian / Soviet tube radios - by Arran - 04-21-2012, 11:05 PM
RE: Old Russian / Soviet tube radios - by Arran - 04-21-2012, 10:26 PM
RE: Old Russian / Soviet tube radios - by morzh - 04-21-2012, 02:21 PM
RE: Old Russian / Soviet tube radios - by morzh - 04-22-2012, 03:29 PM
RE: Old Russian / Soviet tube radios - by Arran - 04-22-2012, 11:00 PM
RE: Old Russian / Soviet tube radios - by morzh - 04-23-2012, 12:16 PM
There are currently 10553 online users. [Complete List]
» 2 Member(s) | 10551 Guest(s)
