2 "Order Of The Black Dial" Radios Came Home With Me Today
Those are very nice. Actually, I just parted with my six tube Zenith radio-phono console I paid $40 for last year. Just needed the room and the cash. Also hadn't gotten anything done on the radio yet. I'd prefer to have the table model of it anyways. Icon_smile
There are currently 8680 online users. [Complete List]
» 3 Member(s) | 8677 Guest(s)
