Unidentified Silvertone
(04-21-2012, 08:11 PM)TA Forbes Wrote:  Hello, Jay: I believe what you have is a model 1720 "Challenger." They were advertised as a 10 tube set at a 7 tube price.
The tube lineup for a 1720 is four-45s, one-6A7, one-37, one-75, two-78s, one-5Z3.
These sets have an "extended" broadcast band that goes (I think) to 1800KHz.
Hi,
The model 1720 is viewable at the Radio Museum site, shows a different dial scale setup, but other than that is real close. The 1725 uses a different cabinet so that's not it. The model 7065 uses the exact same chassis but cannot locate a pic of the cabinet so maybe it is still a possibility? All three models made in '33-34'. John
Unidentified Silvertone - by Jayce - 04-21-2012, 05:55 PM
RE: Unidentified Silvertone - by Carl Travis - 04-21-2012, 07:14 PM
RE: Unidentified Silvertone - by TA Forbes - 04-21-2012, 08:11 PM
RE: Unidentified Silvertone - by John R - 04-21-2012, 09:37 PM
RE: Unidentified Silvertone - by Arran - 04-21-2012, 10:54 PM
RE: Unidentified Silvertone - by TA Forbes - 04-22-2012, 10:13 AM
RE: Unidentified Silvertone - by codefox1 - 04-22-2012, 12:46 PM
RE: Unidentified Silvertone - by Jayce - 04-22-2012, 05:58 PM
RE: Unidentified Silvertone - by TA Forbes - 04-24-2012, 04:40 AM
